Have some problems with the neutral indication
It keeps on indicating even in gear.
After a while the indication start to flash and works correct for a period
But after having the bike standing still for a night or having the bike in neutral while with running engine for a few minutes the problem is back.
Anybody know how to fix this problem
Have diconnected the connection (small plug next to the gear shifter) when problem is ocurring but the indication goes off which gives me the idea it is no dammaged cabel but a problem with the neutral indication in the gearbox
Neutral Indication
MonstroMorini
Re: Neutral Indication
Take out the neutral sensor and check if it works correctly. If so, experiment with different thickness washers, was a common problem with the early corsaro's.
Problem was almost always the last weeks
Yesterday I replaced the washer, quit easy to do and indication runs perfect now
thanks a lot !
thanks a lot !
