a question about the wind screen
Posted: 29 Jan 2016 12:54
by drakoniano
Hi again,
how to move the wind screen? I know that it has 5 different positions but.....can't find it how. If someone can tell me how to move or with any photo please....
Re: a question about the wind screen
Posted: 30 Jan 2016 19:03
by corsaro chris
Hi;
There's a lever below and behind the instrument panel. You pull it back and then you can move the screen, which pivots to give the 5 different positions. If you turn the knob on the lever it adjusts the height of the headlamps to compensate for the pillion passenger / weight of rider.
If you pm me with your e-mail address I'll send a pdf of the user manual, as you obviously don't have one!
Good riding,
Posted: 01 Feb 2016 08:09
by drakoniano
thanks corsaro chris, i send you a pm with my email. I can't find the lever. if you can take a photo....
Posted: 01 Feb 2016 14:00
by corsaro chris
Hi Drakoniano;
I've sent a copy of the hand book, as it has a better photo than I could take, and covers off what is done to adjust the screen, and the headlight as well...
Good riding,
Posted: 02 Feb 2016 07:28
by drakoniano
yeah, thanks a lot. I will take a look when i come back to home.
Posted: 16 Feb 2016 10:00
by drakoniano
Hi again,
I read your manual and found the "button" on the bike, but in the manual only shows where it is, how it works? I Tried pushing down the "button" and try to moving the wind screen but its looks like could be broke (same if i move left or right the "button").
Any advice?
Thanks again
Posted: 16 Feb 2016 10:49
by corsaro chris
Hi Drakoniano;
Using one finger, press the top of the lever towards the tank (backwards) and keep it there; this will free up the ratchet and allow the screen to rotate backwards and forwards. This lowers and raises the screen - if it is in the lowest position already it will only move forwards, which raises the top. There are four other positions, and if you release the lever you'll feel the ratchet engage and keep the screen in place as you move it. The "button" moves backwards / forwards, not sideways!
Turning the knob on the lever will raise / lower the headlamp, which is on a plate connected to this lever by a cable; this allows you to adjust for different ride heights (clockwise raises the beam) which result in carrying luggage and / or a pillion. Useful; if the dip beam goes (after about 11,000 kilometres) you can put it on the lowest position and ride without blinding people coming the other way!
Hope that this helps
Good riding,
Posted: 16 Feb 2016 12:49
by drakoniano
yeah, your post is very helpfull. Thanks again. I will try this afternoon
