clutch holding tool
twisty
clutch holding tool
Post by twisty »
Benelli clutch Holding Tool- fits Wet clutch models
as the benelli clutch is the same this will fit the morini 1200's, unless it has been changed for later models
http://www.ebay.co.uk/itm/Benelli-clutc ... 19d5b7365d
£18 incl postage on ebay
benelli clutch tool.jpg (9.68 KiB) Viewed 8802 times
MonstroMorini
Re: clutch holding tool
Post by MonstroMorini »
Thx, excellent find. A bit late for me, unfortunately ;)
Have just completed rebuilding my engine after exhaust valve broke - have blocked my clutch using bicycle brake cable....
Had to wait months for the new seals - had to be delivered by Morini to the dutch dealer, they took there time :twisted:
Some pics:
Tool to remove flywheel
and running again :D
günni
Post by günni »
twisty wrote:Benelli clutch Holding Tool- fits Wet clutch models
hi twisty,
have you already used this tool? does it fit?
günni
sbarazzino 98, corsaro 125, corsaro 150, corsaro 1200, scrambler
twisty
Post by twisty »
the morini clutch is the same part as the benelli 1130 (wet clutch) , i've had them in my hand to check.
The only thing wrong with the clutch holding tool is it requires the clutch plates to be removed so that the splines on the tool fit the grooves on the clutch.
Otherwise a cheap investment.
