Picked up my used Corsaro a few weeks ago with 2000 miles on it.
Set the front and rear sag for my weight and experimented with compression & rebound settings to get the handling spot on for my style - therefore I know there was nothing wrong with head bearings when I got it. Everything peachy for 600 miles....
......however after a few days riding it in the driving rain we had last week I realised something felt very odd. To cut a long story short the lower headstock/headrace bearing does not have any type of seal on it, therefore the rain had washed out the grease and turned what was left to a half solid grimy slime - and the steering was really notchy and unpleasent at low speed.
I've cleaned it out by spraying WD40 up it, then lubed it with good cahin lube and packed it as best I can with grease - all through the 5mm gap at between the headstock and the bottom fork clamp - feels perfect now and should last until I dismantle it all when I change the front tyre.
To help stop it happening again I've made a neoprene and velcro 'collar' that should stop water getting in and the grease getting out.
What I'd like is other people to shine a torch on this area and see if yours is the same - if I look up the headstock I can just see the bottom of my taper roller bearing. Is mine missing something or are they all like this?
Notchy headrace bearings....mising a seal????
- corsaro chris
I've had my Corsaro for 11,000 miles now, and have ridden it in the pouring rain on a number of occassions
The headlight went onto main beam due to water in the switch, so pretty heavy stuff!
I've not experienced this fault, but am surprised that there is no seal to stop the water - I know that it never rains in Italy (another myth, by the way, I've drievn through floods to get to Orvieto...
) but still! There appears to be a cap for the upper bearing cones, but none for the lower - although it does sit directly on the lower yolk?
Be interesting to hear of others experience here.
