2006 Corsaro upgrade front master cylinder
random
Re: 2006 Corsaro upgrade front master cylinder
Post by random »
On down side of the reservoir I have found number 6J02+16... So probably piston diameter 16mm? But repair kit for brembo 16mm brake cylinder is not available anymore...?? :shock:
random
Post by random »
So I have solved my problem by replacing whole master cylinder.
But I have found, that on Aliexpress is possible to buy only sealing kit for this master cylinder. Price arround 10EUR, much cheaper than buying whole master cylinder. Corsaro has 16mm diameter of the master cylinder.
https://www.aliexpress.com/i/32735488576.html#nav-store
It may help someone in the future.
corsaro chris
Post by corsaro chris »
Thanks for that - useful information for Corsaro riders, although I now have the ZZ version which might have a variation on the original set up (I should check, I guess!) Out of interest the brakes don't seem to be as sharp as on my earlier Veloce - or am I just showing my age and slowing reactions? :D
The Mupo suspension is lovely, though...
Good riding,
