1200 REAR Brake Master Cylinder Brembo
Hi All, the rear brake master cylinder on the 1200 looks like it needs a rebuild kit. The rear brake keeps filling with air soon after every time I bleed it. Then this last time it doesn't want to pump hardly any fluid at all when I tried to bleed it. This is a 1200 Milano but it looks kinda like the rear master cylinder on other 1200/650 Morinis and it wouldn't be a surprise to see it was the same unit. I'm trying to track down a brembo repair kit but I've no idea of the part number (for master cylinder or rebuild kit). Can anyone help?
The unit has 8F07x11 stamped on the body.
Re: 1200 REAR Brake Master Cylinder Brembo
These guys were mega helpful when I needed rebuild kits for various machines
https://powerhouse.uk/motorcycle-brake- ... seal-kits/
Thanks, I gave them a try and very helpful but unlucky they don't stock Brembo. I'm going to try info@addictionmotorsport.co.uk (a random choice) who seem to stock Brembo parts for modern bikes.backfat1187 wrote: ↑21 Aug 2025 17:23 These guys were mega helpful when I needed rebuild kits for various machines
The rear master cylinder is stamped 8F07X11 anyone else out there got that stamped on their 1200 (or 650?) rear brake master cylinder?
Give Addiction Motor Sport a call, as they sell 11mm rear master cylinder repair kits they may be able to help decipher the code.
I think you are lucky in that the Milano was made in Italy, so probably would be Italian parts. Not sure if the new Morinis have Chinese made components.
I do wonder whether the rear master cylinders are repairable.
If you look on the Brembo website only the pads are available for a Milano.
https://www.bremboparts.com/europe/en
Yes I had spotted that. I would have asked them direct except their "support" facility on the website doesn't work, not for motorcycles anyway.
They have a weird thing where they will not sell kits to some markets. Probably for liability reasons. I’m sure they are available somewhere.
