Valve adjusting shim
Stauch
Post by Stauch »
Hi eweryone. Who knows, What outer diameter of the valve adjusting shims on Moto Morini Corsaro 1200? Thank you
twisty
Re: Valve adjusting shim
Post by twisty »
10mm
KTM (some models) shims
and harley v rod
Stauch
Post by Stauch »
Ok. Thank you very much. In near future i am going to overhall valves. Thanks
twisty wrote:10mm
and harley v rod
Rats. YZ450F uses 9.48 diameter and they are very easy to get hold of. Only in 5mm intervals though despite the factory using greater precision on the first build. After doing that (one inlet but both cams have to come off)) and just checking the KTM 350SXF I'm not in a hurry to shim anything else.
