Problem with relays
Posted: 17 Apr 2014 13:55
by kCo
Hi
Just got new fans for my 2007 Veloce. Still not working at 90 celcius. Next guess would be relays. It does not make sound when the fans should go on.
Can somebody help me with this?
Three relays behind front screen, what are their types? and order. The marks on relays have worn of, so they might be in wrong order fex.
I Would apprechiate a lot if someone can tell me the types of these three and assembly order when lookin from front of the bike to rear.
Thank you and happy easter!
Re: Problem with relays
Posted: 17 Apr 2014 18:25
by Chips1953
This is well listed in parts for the Corsaro etc.
Try searching for "Corsaro relay". The part numbers and place to purchase are in the forum.
I guess most of us have got new ones. I got more than enough so that if I had a problem in the future then I wouldn't have to wait to order more.
They are cheaper by the dozen.
viewtopic.php?f=2&t=2527#p12458
The above is a link to a MickeyMoto post about relays, it may help.
Posted: 19 Apr 2014 08:53
by MisterMorini
Chips1953 wrote:This is well listed in parts for the Corsaro etc.
Indeed, I've replaced all of them with Panasonic relais. Both in terms of mechanical & electrical properties nothing beats these. They are fully sealed as well.
The ones with a diode are no longer manufactured but you can use the CM1-R-12V (with a resistance) everywhere.
In fact the one for the fuel pump under the buddy must NOT have a diode. The best is that they are all the same because when you do have an issue you can easily swap some relays on the road & get going again. Not a bad idea to strap an extra one somewhere under the buddy
Posted: 23 Apr 2014 04:53
by kCo
Than You for tips. Now the fans work. Low Beam light stopped working, but that's the least of my problems.
Hopefully this summer goes without of troubles. Veloce has done 28700km so far.
Posted: 20 Jul 2014 20:23
by mart1602
i have had a problem with my lights,only had 1 full beam so changed the relay in centre of the three in front behind fairing ,now i have 1 full beam and 1 dip on either position on the switch.the relay i took out was different as only has 4 pins not 5 as all the others can someone help me out as i dont know where to go from here thanks
Posted: 22 Jul 2014 14:36
by corsaro chris
From memory one light is main beam, and the other dip - i.e., each light has a single filament...
It's the same with the Granpasso - the Sport, 11.5 and Scrambler all have a single headlamp unit with a two filament bulb.
Hope that this helps,
Posted: 23 Jul 2014 21:33
by MickeyMoto
Confirm one dip one main.
Posted: 26 Jul 2014 16:14
by mart1602
yes,one dip and one main at the same time?
Posted: 28 Jul 2014 13:41
by MickeyMoto
No - one dip on dip
One main on main. Never both on at same time.
Posted: 28 Jul 2014 18:46
by Chips1953
MickeyMoto wrote:No - one dip on dip
Unless someone has frigged it. Does occur as the original twin headlight bikes had 2 dip 2 main. There was a change to disallow twin headlights being on at the same time. Some riders were upset about this so frigged the lights to be both head or both dip. I'm saying this is the case, but perhaps worth looking at.
Posted: 28 Jul 2014 20:30
by mart1602
no,as i said one dip and one main on opposite lights.no ones frigged it cos i have had it since new its a 07 corsaro.thanks for the input so far
Posted: 29 Jul 2014 07:59
by MonstroMorini
Chips1953 wrote:MickeyMoto wrote:No - one dip on dip
Orginal headlight have a hi-beam reflector on the left and a dip reflector on the right. So it is impossible to use both at the same time without blinding other drivers.
There has never been a change in design.
