Bike lift
Posted: 21 Feb 2017 08:41
by Gary D
Morning all!
Has anyone invested in a lift for their Corsaro? I'm looking to replace the head bearings soon & need a lift that allows access to this area & the front suspension at large. I've spoken to Abba but they don't have an application that suits. Any other thoughts (particularly from personal experience0, would be much appreciated.
Gary
Re: Bike lift
Posted: 22 Feb 2017 21:03
by floydsveloce
Hi Gary
Have you tried looking at the sealey website ? sealey.co.uk , they have a dozen or so lifts available so you can see if something might be good for you !! If not, try someone like demon tweaks.
As for Abba, I wouldn't bother with the swedish popsters, they won't know anything about bike lifts !
good luck
floyd
Re: Bike lift
Posted: 22 Feb 2017 21:05
by MickeyMoto
Money, money, money...
Use axle stands! Worked for me.
Re: Bike lift
Posted: 24 Feb 2017 07:48
by Gary D
Hi folks
Much as I love the Corsaro, balancing the bike on a V-shaped sump whilst knocking the head races out of the frame is a precarious prospect indeed. Where did you manage to locate the axle stands please Mickey?
Gary
PS Abba seemed to have a "can't be arsed" attitude toward the bike....my mind did drift back orf to being a teenager & a certain other notable Swedish ass
Re: Bike lift
by Gary D
Hi folks
Gary
Re: Bike lift
Posted: 24 Feb 2017 09:32
by MickeyMoto
You do have to be careful! Rear was on a paddock stand. used them under the footrests and used some side supports. It was a bit precarious, but I only wanted to grease the bearings, not remove the cups. Not having a frame underneath does cause problems. The engine is not flat so my normal trick of a plank supported by two axle stands did not work.
Re: Bike lift
Posted: 24 Feb 2017 14:23
by MonstroMorini
There is a usefull one from becker technik in germany
I use paddock stands, have mounted these on the rear, to avoid damaging the speedo sensor when using universal " flat" lifters
IMG_0521 by
Monstro Morini, on Flickr
For the front lifter i bought these adaptors, fit in the bottom hole of the fork
result
or complete lift off
Re: Bike lift
Posted: 24 Feb 2017 16:33
by MickeyMoto
Looks a good, substantial lift, except the forks can't be removed.
Re: Bike lift
Posted: 25 Feb 2017 09:37
by Gary D
Hi folks.
Well..the axle stands are probably a step beyond my bravery levels for race removal. I've enquired on the Becker people, as that option provides for a strap pull down at the rear of the bike to lift the front clear & leave it unobstructed. If they can provide an engine mounting adapter it'll also service a rear end strip. How much it'll all cost is another question??
Cheers for all the thoughts & I'll let you know what happens next...hopefully the word "crunch" won't be included in the summary!
Gary
Re: Bike lift
Posted: 28 Feb 2017 22:44
by backfat1187
Re: Bike lift
Posted: 01 Mar 2017 19:28
by Gary D
Hi Jim
What a bugger..I asked the Abba guys at the NEC about a stand & was met with a firm "no". It makes you wonder sometimes! I've purchases a useful looking centre stand from Germany (off ebay), that uses regular sockets to attach to the swing arm pivot. It looks a stable bit of kit & will hopefully allow me to chock the bike under the sump? At £60 it's worth a punt & I'll let everyone know how it goes.
Meanwhile, the mysterious head bearing rubber gasket remains a mystery in part number terms. I've asked NLM for a word with the factory & have got my fingers crossed. Either way that bike's getting new head bearings soon!
Gary
