Trickle Charger Connection on 2008 Veloce
blackninja
Post by blackninja »
I have a battery trickle charger (http://www.gear4bikes.com/acatalog/Batt ... rgers.html) that I would like to attach to the standard Veloce connector under the seat ... can I get an adapter for this connector? Even if it is a connector with wires to hook up to the charger wires that would be useful...
vtxbrit
Post by vtxbrit »
RS components do a lead with a rubber end that fits permanently to the battery I have cable tied mine to the outside of the frame just under the seat so plugging in after a ride only takes seconds
If it’s a late model optimate here is the link
http://uk.rs-online.com/web/search/sear ... 9080&Nty=1
The connector on the corsaro is an AMP superseal 2 pin connector. You can order them online from vehicle wiring products.
