Idiots guide wanted
Posted: 16 Jun 2025 17:33
Has anyone got an idiots guide to setting up throttle bodies, TPS and CO.
As best I can find is-
Check throttle flaps are touching stops.
Check balance is within1.33 kpa or 10mmHG
If it is out adjust the highest vacuum balance screw out until they do.
Reset tps and setting should be 2.7deg for Corsaro, Scrambler or Sport. 2.0 deg for Granpasso.+-0.2deg
Does anyone know CO setting for use in open loop. I’m guessing 1.5% to 2.5%
Any other info corrections or advice? Thanks
