Started another project Strada 1973
mantaray
Post by mantaray »
A few month's ago a had the opportunity to an early Strada
The A2 3202 with first series engine.
How to recognise those early strada's ? (Thanks to Werner from the German Morini-scene, he discribed it in the last Strega's)
Notice the full allu inlets and other valvecovers
Gearlever is steel and no grip on the frame
Bigger hole on the clutch side, previuos owner filled it up :shock:
No ABC size on the beltpully
For the moment is to hot to drive, so we could spend some time in the garage.
Did a compressiontest first and got 10 bar in front and 11 in the other cylinder
The engine is laying on the workbench ... time to investigatie what we bought ;-)
The odometer says 23.000 but .........
Removed the heads and cylinders and found the missing 1 bar, the pistonring of the front cylinder was stuck
With some WD40 and some patience the ring is free again.
The engine was very clean inside.... really 23.000 km's ????
Measured the pistonrings as discribed in the book.
Perfect 0.20 mm
Pistons in great shape too;-)
No complains about the valves so far (have to remove them) but this looks ok
To be continued
chirpy999
Re: Started another project Strada 1973
Post by chirpy999 »
Good to see someone using this projects section, looks like a nice bike. looking forward to seeing further instalments.
Dave
mantaray
Post by mantaray »
The bike itself is missing some parts, frontwheel and brake is from a MV augusta 350, rear wheel and brakesystem unknown.
I have a second strada and can use that wheels till i have found another set
Front
Rear.
Someone ???
mantaray
Post by mantaray »
some parts, ready to be rechromed
There wasn't a lifting handle on the 78 Strada that recently went through my workshop.
The crankcases look like 250 twin version. Roller bearing engines wouldn't have needed the plain bearing draw-in/press out screws.
mantaray
Post by mantaray »
Yeah Paul,
It's an early engine, one off the first 250.
The parts off the housing d''ont have maching numbers.
Guess it had push rod damage.
other side is damagefree
Other pushrods , bolds too ?
mantaray
Post by mantaray »
New legs for the lady ;-)
And a polished a...
Ready for the ...
... Engine
Fixed ;-)
To be continued .....
danomar
Post by danomar »
Looking nice!
So you are keeping the original wiring then? It would seem such a temptation to redo it all...
:D
Vrrooom!
mantaray
Post by mantaray »
Never had any problems with the morini wiring, so why renewing it ?
chirpy999
Post by chirpy999 »
Thats looking very nice, I agree use the existing wiring. It would take hours to make a new loom ,unless you are an electrical wizard.
mantaray
Post by mantaray »
Still waiting for the chromed parts.
I't's time to open the marzocchies
Bought a set seals and rubbers in Italy http://www.suspensionzana.com
The job was very easy
And got new rims and a golden chain ;-)
mantaray
Post by mantaray »
And the paintwork arrived
mantaray
Post by mantaray »
Bling bling arrived
Before
After
mantaray
Post by mantaray »
Almost finished
The start
Today
Ralph
Post by Ralph »
Very nice a credit to you
Ralph
1975 Strada 3 1/2
Knott End NW UK
Image Image
