Aluminium head gasket
- Parker3865
Re: Aluminium head gasket
Benjy Straw reckons 350 head gaskets will be ok. Once running carbon build up will fill the slight space. I rely on his expertise.
Morini 250 2c currently rebuilding from a box of bits.
Yes I don't see why not, fairly sure all other dimensions are otherwise the same, its only 3mm, or 1.5mm each side oversize,
likely will coke up pretty quickly?
