I am rebuilding my 250 2c Paoili forks. Even with new stanchions I have too much play in the left hand (brake) leg. Does anyone have a spare LH leg complete, or just the aluminium lower, that I could buy?
OR are there alternative forks that fit? Either legs in existing yokes, or a complete assembly? Will 350/500 marzocchis with yokes fit?
See my previous post for progress with rebuilding the forks.
Looking for a new LH fork leg
- Parker3865
- Contact:
Re: Looking for a new LH fork leg
The part number is 42.09.03, I think this is the same as used on disk brake 125H. I don't have a 125 manual to hand.
Did you give Mdina a call - not everything is on the website.
Just out of curiosity what size tubes did you buy, the Paiolis used on Moto Morinis are 31.75mm ( i.e standard 1 1/4 in)
Never heard of wear in these 250 legs before.
Most other Morinis use 35mm so won't fit.
May be there is a small Aprillia or Cagiva set that could work.
I have used an old Yamaha 125 front end, I cant remember which one though , on a 250 2C but that was 30 years ago
- Parker3865
- Contact:
Been in touch with Mdina and no luck. Yes have the correct size stanchions (new from Mdina). Thanks for comments, will keep looking. Have seen forks for the Benelli/Guzzi TS250 which look like they may fit.
Lots of corrosion on the internals, pitting on the inside of the fork sliders. I think they have been stored for years with damp internals.
- Parker3865
- Contact:
Another club member has sourced some replacement fork legs for me, in better condition than mine. So repaint and then reassembly happening now.
