Tank supports
Posted: 06 Feb 2024 18:37
by Parker3865
My box of bits did not provide any way of fixing the tank to the frame. I have managed to get hold of some rubbers but do not have the inserts that screw to the frame or know which hole is used by the steering head gusset. I have circled which bits I mean on the images. Cut from the parts manual so may be small! I can make the inserts if someone has the dimensions. I assume they are different for the front and rear?
Part 10; 13.04.39 (described as cable end but appears to be for the tank rubber?)
Part 13; 13.04.38 Bush.
Many thanks.
