Hi everyone, can anyone tell me what the red wire is for only the early type alternators?
After my disaster with my Excaliber one, i am putting my original one back on (while i attempt to rebuild/rewind the busted one) and the excaliber one did not have a 'live' feed to it, just the green wire, a white earth wire and two yellows. So i'm a bit confused!
Thanks, Tony
						Whats the red wire for?
				SoloFrenos
Re: Whats the red wire for?
That everybody can explain better than me
But for the Excalibur alternator you need another regulator than for the one with the red cable, that´s for sure.
The red wire is the centre tap on the alternator winding and connects directly, or indirectly to battery positive.
It works in conjunction with the low side switching half wave rectifier/regulator.
I'm sure that makes it all as clear as mud. Most people have enough trouble with electrics, let alone electronics in slightly unusual topologies.
				TurboRestorer
Wiring diagram shows the red connection on the fuse box connects ignition switch & alternator red wires.
									ZRX1100 1999
KLR650 1990
750 TURBO 1984
SV650 2001
MOTO MORINI 3 1/2 STRADA 1981
						KLR650 1990
750 TURBO 1984
SV650 2001
And to the battery.TurboRestorer wrote:Wiring diagram shows the red connection on the fuse box connects ignition switch & alternator red wires.
