little problem?
little problem?
Hi guys my morini cant run on low rpm..i start him(not on kick start he push it back) when he runs all okay he goes well..sparks color are okay..i think pick up sensor is not adjust fine..i adjust im like this..when is piston in tdc and intake valve is open..is that corect..help someone about that pick up allready!!
									"Riding a bike is an Art , something you do because feel something inside"
Bikes:
Moto Morini 350 X2
Moto Morini 501 supermoto
Bikes:
Moto Morini 350 X2
Re: little problem?
The stock Morini system doesn't fire until after TDC at kickstart speed, so it can't kick back.
Static timing is set by aligning the mark on the pickup with the mark in the side case, then the dynamic timing set using a strobe and the marks on the flywheel.
Don't you have a manual?
