Non resistor plug caps needed
BobPickett
Post by BobPickett »
Hi, anyone know where I can buy non-resistor plug caps?
Straight would be OK, or a 45 degree angle.
All suggestions greatly appreciated,
Thanks,
Bob
hendre
Re: Non resistor plug caps needed
Post by hendre »
just make some youreself :mrgreen:
see this PDF for all NGK plug caps : https://filehorst.de/d/dpctFmuD
and adapt according to the picture (sorry, text in dutch). "weerstand" = the resistor & "balpen veertje" = spring from a ballpoint pen (or a copper/metal equivalent)
Job done!
Richard
Post by Richard »
'www.gsparkplug.com/ignition/spark-plug-caps' if you can manage with 90 degrees.
hendre
Post by hendre »
NGK 1 kOhm caps also work fine, you can use this off the shelf: NGK SD01F (straight version)
