Clutch overhaul tools
martinaccarter
Post by martinaccarter »
Hello All
I have a small oil leak from the clutch cover on my ‘77 Strada and so need to replace the seals. I’ve seen Paul’s excellent video but I have a question re special tools. I think I need one to remove the clutch cover and a second to hold the clutch basket when I slacken the central nut.
I wonder if anyone has any tips concerning such tools? I see the manual suggests modifying a 14mm screwdriver for the clutch cover but the cost of such a screwdriver is no doubt more than the cost of the special tool (admittedly if I could find one)
Any suggestions most welcome
Martin
Re: Clutch overhaul tools
You can often get by with a standard screwdriver if the stud nuts have not been overtightened or have not been left undisturbed for years. I use a tool designed for BSA/Triumph clutches which works OK.
To hold the clutch 'hub' I use an old plain plate with a length of steel strip bolted to it. A universal clutch holder might also do the job. I have a Motion Pro one that also works on my 57 Gilera, but much cheaper ones are available.
I only have these tools because I was regularly swapping clutch stacks between bikes when hill climbing.
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
Fastmongrel
Post by Fastmongrel »
1981 3 1/2 Strada
martinaccarter
Many thanks for your response. Yes I should
have said ‘hub’ as opposed to ‘basket’! I’ve found one of the BSA/Triumph tools on eBay so many thanks for that. Unfortunately I don’t have an old clutch plate so I think I’ll try a universal clutch holder
Thanks again
martinaccarter
Fastmongrel wrote: 27 Jul 2023 12:36 Service tools for Morini
https://www.mdinaitalia.co.uk/morini-service-tools.html
Thanks for this. Unfortunately the two tools I mentioned are out of stock
70sbikes
Post by 70sbikes »
I bought a generic clutch holding tool off Ebay. I did have to grind the holder parts of the tool until they were a snug fit in the hub splines, but after doing that it worked very well.
Trevor
70sbikes wrote: 28 Jul 2023 03:28 I bought a generic clutch holding tool off Ebay. I did have to grind the holder parts of the tool until they were a snug fit in the hub splines, but after doing that it worked very well.
Trevor
That's pretty much like the one I have, though I've not used it on a Morini yet.
Going to get stuck in to stripping down one engine soon, so I will bear in mind it may need tweaking, though the trusty plate and strap are still in the 'special tools' drawer. At least you don't need a puller to get the hub off. Unlike the Gilera where I had to get inventive with a two leg puller and a piece of dural.
Honda: 1984 CB250RS
martinaccarter
Trevor
Thank you Trevor I will go down this route
Fastmongrel
martinaccarter wrote: 27 Jul 2023 19:41
Oops I didn't look before posting the link. That's the problem with owning rare old bikes and cars you can't just go to Halfords for the bits you need.
1981 3 1/2 Strada
Fastmongrel wrote: 28 Jul 2023 09:17
Some may say that is fortunate! :)
Fastmongrel
To be fair to Halfords the Pro grade tools are top notch especially as you get a lifetime warranty though I believe they want to see a receipt before replacing nowadays.
I have some of my dad's old Halfords tools from the days when they were made by Britool, Gordon and other quality British names. The 1/2 socket set has been used and abused and never let go though the ratchet direction switch is getting a touch sticky. I once used the breaker bar to undo flywheel bolts on a Bedford diesel engine it was in a canal boat and I had to cut a scaffold pole to exactly the right length so we could swing it inside a cramped narrow boat engine bay. 2 burly blokes swinging on the pole and it stood up the socket didn't survive and I had to burn some of the bolts off.
I have a set of Halfords advanced whitworth spanners that I bought with a Xmas voucher and they look brand new after 20+ years of use on crusty old British bikes and cars.
1981 3 1/2 Strada
I have Halfords Professional tools, so far so good. I kept the receipts!
