I ask because the blue book says the tank holds 12 litres with only 1.1 of that reserve but on the odd occasion I had to bring the right hand tap into play there seemed to be much more than 1.1 litre in it. I'm going to do a manual fill up calculation when the weather's a bit more reliable but would appreciate other members sharing their experiences, tank ranges, range before and after reserve etc. Cheers!
And still, I remain confused...
Hello everyone, here's another borderline dumb musing as I DON'T go for a ride today due to tropical temperatures coupled with gale force wind gusts and heavy showers that appear and disappear without warning. I was helped muchly when i was advised that my initial running of both fuel taps was only necessary for hard riding, possibly motorway type trips also, which of course i try to avoid. i was further advised the right hand tap is really a reserve so my question is this, on my MK5 Strada with both taps mechanical, has anybody got any idea what the approximate range is when going onto reserve?
Re: And still, I remain confused...
You'll only find out if you do as you say and actually measure it. The amount left when you hit reserve depends on the height of the stand pipe inside the main tap. By now the chances are the tap has been replaced (ie your mechanical tap) and who knows what is there now. I sometimes have cut that pipe down a little as reserve was needed way too early. It's a trial and error thing, you could maybe drain the tank via the main tap into a jerry can. Then drain via the reserve tap into a container you can measure the amount left for emergency? At least that way you can estimate how far that number of litres will take you. Then you can worry about how your driving style will affect the range you have left-it's great fun honestly!
Fuel remaining at reserve is not a good indicator of range. How much can be used? The tank may not run dry before the fuel stops flowing. Also, do you really want to drain the bottom of the tank, it is probably full of crud which will block the filters on the taps and the carbs and some will find its way in to the float bowl.
I recently helped someone who needed to drain their tank. We drained the lhs using a pipe from the tap spigot into cans without apparent problem. We then connected the hose up to the rhs (reserve) tap and watched for fuel... nothing. Tried cycling the tap positions... still nothing, but there was clearly fuel sloshing about in the tank. Pondering the possibility of a blockage I gave it a godd lungful blowing back up the pipe. Sure enough, nothing happened other than I succeeded in getting redin the face. Another couple of long sustained blows back up the pipe and finally the sound of bubbling could be heard. We then drained about 1 litre from the reserve side before the flow dried up. There was still fuel in the tank, so we tipped the bike over onto its rhs and tried again. More came out, but not a great deal. Conclusion: Reserve was blocked and was probably of no use and both pipes were positioned such that accessing all the fuel in the rank would have been impossible. Moral of the saga; check and clean the tap filters and check their height, goodness knows when they were last cleaned!
Thanks for all the replies, I’m going to spend a day clocking both ‘tanks’ but as always, a great deal of relevant info, thanks
If it can be drained from the reserve tap it can also still be supplying the carbs. So of course it is relevant! If the state of your tank is such that there is crud in the bottom it needs draining anyway, surely? Ref how far is possible on what remains available, that depends on how you rideMickeyMoto wrote: ↑10 Apr 2024 06:23 Fuel remaining at reserve is not a good indicator of range. How much can be used? The tank may not run dry before the fuel stops flowing. Also, do you really want to drain the bottom of the tank, it is probably full of crud which will block the filters on the taps and the carbs and some will find its way in to the float bowl.
Ok, so in between the rain I managed to get 281km out of a tank that had been on reserve for around 15km, I make that just over 174 miles of mixed riding including a little bit of motorway work. I'm quite happy at that because I re-filled with 11.83 litres of the best E5, making it 15.11 miles per litre or just under 66mpg. Standard Strada (I think), with 520 conversion & 39t rear sprocket. For a 45 year-old fairly sprightly classic, often ridden in a spirited manner, I think that's pretty good and assures me the old girl is in fairly good health
i have taken my tank off for cleaning and on examining the taps i'd like to know what sealing washers are used as they are both just plain washers with loads of ptfe !. i was expecting a proper washer with a rubber centre of some kind
There should be a flange on the nylon filter screen of the original taps. That is all that is needed as long as the mating faces are good. So no extra dowty washers etc of any kind or PTFE!
DOWTY washers ! that's what you call them, thanks steve that was bugging me.
- George 350
You might require some (10mm?) sealing washers - aluminium or copper between the tap and tank. I know I did.
They need to be a close fit to the filter and reasonably close to the inside diameter of the nuts too.
Not sure where I got mine from now, but do know mine wouldn't seal without them.
Good luck,
Good luck,
thanks George. mine has a close tolerance washer fitted i'll see if i can find some
