low to mid range flat spot
Re: low to mid range flat spot
It has VHBZ carbs and has new rubber manifolds that I have fitted but not sure where the balance pipe would go, this would help me greatly if it had that, yes it does have a tail piece
Thanks barney
Thanks barney
Hi Barney,
Please see photo, the tube running up under the tank connects with the other carb. This is the balance port. If you look at the inlet rubber there is a boss where a hole was drilled on earlier bikes to put a takeoff for balancing. There was a mushroom shaped piece of metal that filled the hole when not in use.
- jpeg-optimizer_IMG_20250613_155524.jpg (92.65 KiB) Viewed 105 times
The balance ports Mickey refers to are on the carbs, not the rubber inlet mounts. There is usually a rubber pipe connecting one cylinder to the other, but they may be blanked off by a previous owner.
Thanks for the picture, these don’t appear to be on mine
- IMG_1379.jpeg (318.16 KiB) Viewed 101 times
- IMG_1380.jpeg (102.8 KiB) Viewed 101 times
Blooming 'eck! Italian manufacturing!
Try doing something on the intake rubbers. I've seen a take off fitted from the inside glued in with a screw on cap. I think it is essential on a Morini.
I’m working on the carbs at present, they will have vac ports by the end of Today, Thanks for the pics
Any other ideas to make this slightly better or do I have to put up with it, it is more rideable but hard work when 2 of us go out
Thanks barney
Mikuni's!
Didn’t really want to go to the expense of that really, I guess it’s new cables as well ?
It is how the Sport is. Use the gearbox. Back in the day it was reckoned to being akin to a two smoke. As I have aged (not matured) I prefer the gentler Strada.
Hmm, I thought that might be the case, and your right my 76 Strada is a nicer ride, I bought this as at the minute I’m struggling to start it due to a herniaMickeyMoto wrote: ↑16 Jun 2025 15:33 It is how the Sport is. Use the gearbox. Back in the day it was reckoned to being akin to a two smoke. As I have aged (not matured) I prefer the gentler Strada.
Transplant the flywheel and casing to the Strada!
Now that might be a plan, little winter job maybe as it will involve some wiring as and handlebar controls as well I guess, I will look into this now, Thanks for planting the thought
Yes, home-made cables using Sturmey Archer three speed bicycle bits.Didn’t really want to go to the expense of that really, I guess it’s new cables as well ?
I struggled for years trying to tune the Dellorto square slide carburetors. The Mikuni carburetors took a little while to get right, but once they were dialed in, the bike was transformed. No flat spots, a pretty consistent idle, starting is a bit easier, and when you whack open the throttle while cruising the bike actually jumps forward without hesitation.
maybe if I keep it, bought it because of the elec start, hernia op in about 3 weeks so hopefully back on my Strada after that.
What model are they please, I will have a look and see what the cost is, I can do my own cables and brackets to steady them
Thanks barney
Thanks barney
