Mirror Mount
Andy_C
Mirror Mount
Post by Andy_C »
Not sure how the mirrors are mounted originally, but on mine the mirror mount i.e. the bit that carries the thread to screw the mirror into it is on the back half of the clamp that holds the brake lever / resevoir to the handlebars.
The issue is that the clutch lever clamp does not have the thread to take a mirror so I only have a mirror on the RH side.
I took a look on the Mdina website hoping to find a clamp for the clutch with a thread in it but no luck - anyone know if you can get a clamp specific to the Morini, or is it a case of trawling E Bay until I find something the right size?
I miss not having a LH mirror as all my other bikes have mirrors on both sides.
Thanks.
Re: Mirror Mount
I fitted bar end mirrors. They vibrate a lot less than handlebar mirrors and I can see more road behind. Some are available that fold up if you need the space, as they do make the bike wider.
Re: Mirror Mount
Clutch lever mounts with mirror bosses are available, and to be honest, when you bought a Morini in 1978 (and earlier) that's all you got.
No boss for RHS mirror. As a result, I'm with Mickey, with bar end mirror only.
If you want to keep your existing lever, why not try a 'wanted' ad?
AntietamClassicCycle
Re: Mirror Mount
I've used these on vintage Guzzis without means to mount mirrors.
https://buywitchdoctors.com/products/un ... o-20-28125
Andy_C
Re: Mirror Mount
Post by Andy_C »
All due resptect but I dont like bar end mirrors, I like old school handlebar mounted ones - perhaps I just like seeing multiple images of what is behind :D
Think I have found the solution, the clamp on the clutch on my Himalayan will fit and it has a threaded boss for the mirror, and it does not look too out of place .
Available from E Bay for a tenner.
Cheers.
FatherB
Re: Mirror Mount
Post by FatherB »
I have a 1976 350 Strada that has the original chromed steel lever mounting clamps with no provision for mirrors. I drilled the clamps with an 8.5mm bit and tapped a 10mmx1.25 hole in each one. Although the steel clamps are not solid unlike alloy ones they're holding the 2 chrome aftermarket well so far. I also used a spring washer under the long top nut. If you're worried about them coming loose you can always screw them far enough through to put a nut underneath as well. I didn't do that and all's good so far.
70sbikes
Re: Mirror Mount
Post by 70sbikes »
I recently bought a "GP Clutch Lever Mount 7/8" front brake perch for my 3 1/2 Sport from 4into1motorcycleparts on eBay (because the action is so much better than the Morini original). I complimented this with an alloy mirror mount from AliExpress. Some nice AliExpress 10cm stainless mirrors finished it off quite nicely. Having two mirrors is nice...
Trevor
