Possible disc replacements
Richard
Re: Possible disc replacements
Post by Richard »
Bison wrote:Hi Richard,
The floating disc is lovely, and works very well. No problem with the clearances.
Dean is very busy, you have to keep on at him sometimes, it took a while to get my disc, but it was worth the wait.
I think it was around £137, but that could well have gone up?.
Alan.
Thanks for that, Alan. Looks like the way forward for me at last. The bike is horrible to ride at the moment; OK on the move, but you know that you are going to have to stop at some time. Can't be doing the forks much good either, but my main concern is rider comfort!
Richard
Steve
Post by Steve »
Discs by Roy Thursby
disc (2).jpg (397.72 KiB) Viewed 7583 times
Motomat350
Post by Motomat350 »
Hello:)
Know it’s an old thread, but guess the topic aren’t :D
Is there any problem going with a thinner disc? The semi-floating ones, I can source, seems to be only 4mm thick vs. the original 6mm.
Happy riding!
Motomat350
For anyone looking for new disc’s.. I Found these at a cheap for a cheap price: https://oem-bike-parts.com/en/parts/mot ... brake-disc
Stempy
Post by Stempy »
Motomat350 wrote: 21 Mar 2025 16:33 For anyone looking for new disc’s.. I Found these at a cheap for a cheap price: https://oem-bike-parts.com/en/parts/mot ... brake-disc
Did you purchase the discs ?
Rocker62
Post by Rocker62 »
Paz2112 ref front brake master cylinder alternatives. I use a Triumph Sprint ST 955i front brake master cylinder ( other Hinckley models also fit ) which I got for 22 quid off eBay. Transforms the front brake action. Also use one on my Laverda triple.
Steve.
Rocker62 wrote: 17 Oct 2025 07:19 Paz2112 ref front brake master cylinder alternatives. I use a Triumph Sprint ST 955i front brake master cylinder ( other Hinckley models also fit ) which I got for 22 quid off eBay. Transforms the front brake action. Also use one on my Laverda triple.
Steve.
Twin disc or single on your bike?
Rocker62
Post by Rocker62 »
Twin disc Steve.
Steve.
Ah OK,that makes sense, thanks.
Stempy
Post by Stempy »
Any one found a disc replacement ?
Andy_C
Post by Andy_C »
Rocker62 wrote: 17 Oct 2025 16:26 Twin disc Steve.
Steve.
Hello there was just reading through this thread and read your recommendation for a ST 955i cylinder - so all you have done is swopped out the stock master cyl for the ST 955i one, everything else is stock ?
Only asking because mine has double discs, and despite the brakes being very good, the action leaves a lot to be desired, if fitting a ST 955i cylinder improves things then it sounds like a worthwhile mod.
Rocker62
Post by Rocker62 »
Hi Andy it’s a straight swap. You may have to have the Triumph banjo bolt as off the top of my head I can’t remember if it’s the same thread size as the Morini. It makes a massive difference in feel. I have the banjo bolts if needed. They also have an adjustable dog lever for the span which helps too.
Steve.
Rocker62
Post by Rocker62 »
I was lucky and got this for £22 a few years ago.
Andy_C
Post by Andy_C »
Thanks for that, might give one a shot on mine.
If it gives the brake a bit more "feel" / makes it more progressive that will do me. As it is the brake is a bit binary !!
Seems to be a few on E Bay at the moment.
