I have always re torqued the head / exhaust fittings after the first run on any bike that I have had after a rebuild - just think it is good practice.
Nothing in the Blue Book about re torqueing after the first after a rebuild.
Any thoughts, just do as I always have ?
Appreciate a re torque means taking the rockeer gear off but probably worth it.
Re Torque or not?
Re Torque or not?
- George 350
Re: Re Torque or not?
Personally I've not bothered to retorque the heads on my Morinis since the aluminium gaskets came into use, and haven't had one leak yet due to torque relaxation.
Exhaust port nuts are another story however, as they need tightening a few times during the first hot engine runs.
Thanks for that George, good to hear from someone with experience.
To be honest I was not looking forward to having to take the valve gear off again.
Appreciate that the exhaust nuts will a re torque.
Just need some decent weather to get the new rings run in.
To re toque the exhaust nuts is absolutely importante.
I've been used to re torque the head nuts after 500km. Lately I've given these nuts a bit more toque than required when mounting the head. Then wait one or two days, lösen the nuts and give them the right torque.
So I dont have to take of the rockers again. For me that works well.
Thanks Norbert, I followed the guidance on torquing the head bolts in the Blue Book.
I'll keep an eye on things but I will remember to tweak the exhaust nuts.
