I took my Tachometer apart, can it be saved?!
Guzziando
Post by Guzziando »
The capacitors have exploded, and it looks prety nasty inside. I do not have a problem with replacing components, but what else do I need to be aware of that could mean that it is not worth repairing. The needle is stiff, and does not bounce back. Is there any reference material for rebuilding Veglia Tachometers?
Guzziando
Re: I took my Tachometer apart, can it be saved?!
Post by Guzziando »
Further pictures:
Guzziando
Post by Guzziando »
Further pictures:
Whilst no one has replied, I know that some people with way more knowledge than me have done a repair/rebuild of these, but it isn't an easy job.
The most recent posting on this subject was that somebody replaced the 'guts' inside with those from a cheap Chinese generic rev counter for very little cost.
Might be worth a search.
Regards, George
Tinker
Post by Tinker »
I don’t know anything about them. But if it was mine I would try to save it! Capacitors are cheap if you can get enough info off the old ones! Is the rotor free? Are there any electricalcontacts on the rotor? Good luck
scbond2@yahoo.co.uk
Post by scbond2@yahoo.co.uk »
Maybe try Bengy Straw?
Maybe try an instrument expert like The Gauge Man, Peter Bond.
I believe that Mark Bridger of this parish has repaired one, but concluded that it isn't commercially viable to do so (?).
Only other help may be to look up 'Ferrari Dino' rev counter repair as they are very similar inside.
Guzziando
Post by Guzziando »
It has been a while ago, but I finally got around to fixing my Tachometer. I bought a very rusty Tachometer from a club member, I had no idea whether it would work, but after testing it, the electronics seemed OK, but the mechanism was not great. I bought another Tachometer from Ebay as 'spares or repair', it was labelled as a Veglia Electronique. The mechanism was in good condition, so I put the two together. USing a 12v A/C output signal as shown by Paul Compton in his video, I was able to tune the Tachometer somewhere near. I then attached it to my bike to try and get it more precise. I did get the bezel fitted by Timeless Motorcycles, they were really good to work with.
That’s a really good outcome. Both mine are of the mechanical variety but it has spurred me on to try and repair my electronic tacho from a BMW which stopped working.
BumbleBee
Post by BumbleBee »
George 350 wrote: 22 Aug 2025 09:17 I believe that Mark Bridger of this parish has repaired one, but concluded that it isn't commercially viable to do so (?).
Three MRC members, Mark, George (not you George) & Gary have an arrangement between them whereby they are able to build and fit new circuit boards to 3½ and 500 tachos. As they originally set this arrangement up to fix some tachos for their own bikes and a couple of friends it isn't an advertised service. But if you were to ask you could find out if they could help.
Sometimes the problem isn't the circuit board in which case the fix cannot work.
Guzziando
Post by Guzziando »
Now he tells me :!: :roll: Useful to know for the future, should it fail again....
BumbleBee
Post by BumbleBee »
I should also say I can properly fit new chrome bezels to speedos/tachos for the 3½ and 500. I can "supply and fit" or just "fit". Agreed its a bit late for you but it might help others who might read this thread.
