Thanks...
Plastic Instrument Surrounds
Hi, does anyone know if i can get new ones of these? The circular black plastic surrounds, that have those "oh so strong" 3 little fixing lugs that seemed to snap like dry twigs when i went to remove them! I need two! (and the horrid metal clips that hold them in place).
Thanks...
Thanks...
Re: Plastic Instrument Surrounds
There are stainless replacements.
Sorry, not the metal plate, but the plastic circular 'cowls' almost, that go over the clocks, and are secured on the mounting plate by three plastic lugs....
There are stainless replacements!
These from http://www.morinibadges.com/products.html
Oh and you might have heard of North Leicester Motorcycles?
The rumor is they do one or two Morini bits
Ahhh stainless replacements.... lol sorry, i thought you mis-understood.
Thanks, look nice but would prefer to keep the bike looking as 'original' as poss, have emailed stuart at NLM, but he normally takes ages to respond!
NLM also do plain steel ones..... Paint em black?
- George 350
Unless you are really wanting/doing a 100% concours, then If you still have the original rings, drill a dia 2.5mm hole approx 6mm deep where the snap off peg(s) used to be and use an M3x8 screw/washer to retain the rings. No need to tap a thread, the screw will do it. Looks way neater and is easier to clean this area as the cleaning cloths have nothing to snag on.
Hope that this helps,
