Hi all, I apologise for all these questions, I'm doing a lot stuff I haven't done before!
I'm putting the loom back on, I've replaced any obviously dodgy wires, but what resistance should I be getting on a sound connection, seem to be getting around 1 ohm through the wires I've tested and 0.8 through the frame earths.
Is that within acceptable parameters?
I know I should have listened harder in my physics classes forty years ago...
Simon
Resistance
mad muller
Re: Resistance
cant say i know the answer to that one , but had to a bit work on the wiring make sure all the earths to frame are clean and tight same with all spade connections and everything should be fine.
Re: Resistance
What resistance do you get from your meter leads?
Re: Resistance
Hi Paul, I think you've opened my eyes to the obvious...
Just borrowed a digital meter and realised I'm getting 0.6 on the meter cables and 0.6/0.7 on the loom and earths, so that looks good to me. As I said a lot of this is a learning curve for me, but hey, that's what makes it interesting!
Thanks for the input.
Simon
Simon
