Banjo Bolt size
Banjo Bolt size
Could anyone tell me the size of the banjo bolt for the front master cylinder. Looking at getting a Banjo Bolt pressure switch fitted so the brake light will work off the front brake.
Si
Si
morini500dave
Re: Banjo Bolt size
Hi Si.
The banjo bolt thread size is 10 X 1.25 mm.I had the same set up on my 500.
Welcome to the forum.
Dave.
Dave.
Re: Banjo Bolt size
Thanks Dave. It worked OK did it?
Si
Si
morini500dave
Re: Banjo Bolt size
Hi Si.
Yes it worked fine.With the 500 set up I had the switch mounted on the brake pipe union which is on the bottom yolk of a twin disc set up.You can get either single or double banjo bolts,I bought mine from Venhill.
Dave.
Dave.
Re: Banjo Bolt size
An update on fitting a front brakelight switch to a '79 3 1/2.
The M10 x 1.25mm switch I bought did not fit the Grimeca MC, must be a different thread to the banjo on the 500 yolk. Bought a M10 x 1.00 switch which fits great. All wired up to the same fusebox connections as the rear brale light and works great.
Hopefully my brother will now not complain my brakelight doesn't work, I very rarely use the back brake.
Si
Si
morini500dave
Re: Banjo Bolt size
Hi Si.
Sorry the info I gave you did'nt match that of your bike which has got me wondering if my bike's bolts are all the same?
Dave
Dave
Re: Banjo Bolt size
No worries Dave.
Some bikes do seem to have different size bolts in various places.I'll stick the other on E-bay some time. The first one I ordered never arrived so they sent me a replacemet. Otherwise I would have found out earlier.
Si
Si
Re: Banjo Bolt size
That's interesting, I'd (wrongly) assumed they were all 1.25 pitch.
I was about to order new brake lines and banjos....
So it's 1 pitch on the master cylinder, 1.25 at the union, and 1.25 at the caliper?
Simon
Simon
Re: Banjo Bolt size
Posting attempt 10.
Might be worth checking them all before ordering new lines. Not sure what size the calper is.
Si
Si
