Steering Damper.....
robint
Post by robint »
It leaks - not much, just an annoying little bit. Been leaking for a number of years which makes me wonder why it isn't empty.... Presumably by now it is also less effective than it was.
I gather repair seems impossible (correct me otherwise please) and new ones are thin on the ground. Would a gas strut of appropriate size be OK - they come in all sorts of sizes and strengths and are reasonably cheap (£20-30). SGS in Derby seem to offer almost every permutation known to man for example.
If so, any idea on the number of Newtons resistance - still need to be able to steer a little bit!
robint
morini500dave
Re: Steering Damper.....
Post by morini500dave »
Hi Robint.
I've seen the same steering dampers being sold by M&P but that was 2-3 years ago,maybe worth taking a look?
Dave.
morini500dave
Hi again,thought I'd follow up my previous e-mail so went on the M&P web site but they had a fire yesterday 26th so could n't go any further.hum ho!!!
Dave.
morini500dave
Hi yet again.
Found the steering damper that I'd identified a few years ago on a Busters web site being the same company as M&P,it's listed as a Kawasaki style steering damper,no price listed for it though :?:
Morini500dave...
morini500dave
Damper on e-bay item number 360376334598.
Dave. :lol:
atreyu
Post by atreyu »
That just looks like a "classic" type universal one? I've seen them cheaper. I had one on my race Ducati and took it off.... I cant see any need at all for one on a road bike? Apart from to look original?
morini500dave
Hi all.
Had one on my 78 500 which looked the same as the one on e-bay,took it of as it was leaking and dripping on to the front pipe and staining it,really never needed one in the first place?
Dave.
unreal
Post by unreal »
robint
Post by robint »
Thanks for finding those Simon - certainly look the part :D . WIll check dimensions in the morning with the seller. Price is fine as well.
Not convinced either that I need it, but quite like the look of them.......
No-one any opinions on the use of a gas strut?
robint
atreyu
Post by atreyu »
Are gas struts equal damping both ways? For the money you can pick up these classic style dampers (like the ebay one) which are the real deal.... I'd stick with a proper steering damper, the one on the Guzzi site isnt exactly dear either. I certainly wont be putting one on my Morini though, I think it will ruin the experience! :lol:
John Bunting
Post by John Bunting »
No-one any opinions on the use of a gas strut?[/quote]
I think you will find the gas strut is not a damper, it uses compressed gas as a spring, OK for supporting the weight of your car boot or bonnet??
splitbus
Post by splitbus »
I have a Morini 500 s
Just took it out for the first ride after winter storage.
Before winter storage I got the rear dampers and the front tubes replaced
On the first ride it start woobbling a medium speed, large curve. It was scary :(
I was thinking on ajustable problem in front tubes after resample ?
Steering damper dried out during winter time
Anyone with some input to how to fix it ?
/lars (dk)
Unless you're pushing very hard on track, there should be no need for a steeing damper. If you've got a wobble, then something is wrong. Perhaps you've got head bearings way out of adjustment, or missaliged or loose forks.
I never had a damper on the Morini but I have had them on 2 BMW's and removed them on the basis that there must be something wrong if you needed one, such as steering head bearings/dodgy shocks or underinflated tyres. but then again a Morini doesn't have a bolt on subframe to contend with.
And yes indeed the beemers have had all of these issues.
