Where to start on my 350 Strada
Posted: 27 Sep 2011 18:58
I've recently aquired a 1980 350 Strada and am doing that chin stroking excercise that accompanies a 'new' bike where I'm trying to assess what I actually have in front of me.
Most of it is obvious cosmetic stuff, while tatty it seems mechanically sound and in due course I'll get round to all of it hopefully.
Registered in Feb 1980 I suspect its a bit earlier with its A marked engine and while I can see the frame numbers the paint makes them illegible so I'm just going on the V5 for the moment, it also assigns an engine number but I cant see that so maybe am looking in the wrong place.
I do have couple of queries though and am open to suggestions. My only previous experience of Morinis was my mate had a sport in the late nineties, enough to interest me in eventually getting one but thats where my knowledge runs out, I've been firmly in the Ducati side for the past fifteen years.
paintwork, the frame is decidely orange compared to the tank and side panels, it may well be the original colour as theres a grubby made in Italy sticker under the headstock. I'm debating whether or not to repaint the whole thing (tank and side panels need it really)or leave the frame as is, wheels will need recoated too
The headlight switch has gone, it still work if I push it with a screwdriver but I'd like to know what else will fit.
I suspect the tape aroung the headlight bezel is for more than waterproofing, haven't had a look yet so dont know whats in there.
Is it meant to have a front brakelight switch? this one doesn't,not that I'm to worried, the rear pedal works fine but I'd like to know what should be there.
Indicators probably disappeared years ago, I'll consider them in due course.
I do have a replacement belt, marked 'MEGADYNE ISORAN 124L 811' ,anyone know if this is suitable, the previous owner seemed to think so but I'm just checking.
I suspect the front cylinder has been replaced at sometime as its black and the rest of the engine is silver(well under the muck it is), the engine has a charming film of oil across the bottom of the case, its source will be more obvious when its cleaned but if theres a 'usual suspect' I'd like to know.
I'll look around here for tyre recommendations, the ones fitted seem fine but as far as I can tell from '1902' they were made in the nineteenth week of 2002 so may be past their best.
The lauded electric fuel tap seems to have been replaced by a standard fuel tap, can you still get the oe ones?
I'm open to general fettling suggestions as I haven't taken on a bike this old before, I'm in no hurry though.
Specialist tools may be a stumbling block and I'd rather know about them before I start something only to find the innaccessible little widget is only removable with a special tool made in one little shop in Volterra which is shut nine months a year.
