Rear Brake switch
unreal
Rear Brake switch
Post by unreal »
Hi all, as the Strada progresses I have just fitted the Valentini 2-1 pipe, what a sod! They are very tight and I ended up making spacers etc. Anyway, it looks like the rear brake light switch will no longer fit as the pipes too close. Does any one know if there's a rear brake cable with an inline brake switch, or who might make one up? Also is a rear light switch a legal requirement if there's a front switch?
Simon
chirpy999
Re: Rear Brake switch
Post by chirpy999 »
Yes , you can get one from one Nlm , they are about £25.00
unreal
Post by unreal »
Cheers, I couldn't see it on their parts list, I'll give Rob a call tomorrow.
Simon
morini500dave
Post by morini500dave »
Hi,only one brake light switch is needed on front or rear on bikes up to April 1986 :)
Dave.
I had the same problem on the 2C/375 with a 2:1 system. No brake cable with a switch available for a 250. I managed to rig up a generic pull switch mounted on a clamp on the frame and with a bit of twisted wire joining the return spring to the brake pedal. Crude but effective.
