Treatment?
Posted: 30 Nov 2011 09:52
If you have an untreated engine case (assume the early 3 1/2 falls into this camp) (alloy) that is a bit oxidised what do you recommend for cleaning - ideally with the engine in place...so not a dismantling job and then off to bead/soda blast etc.
I have used solvol, belgom alu, and that sort of stuff in the past but thought I'd ask for advise...
Do I need maybe coke (head that sometimes can be used as a cleaning agent) as well as some toothpaste/concrete cleaner etc etc and maybe even green nylon kitchen pad/scourer/brillo pad ...
http://www.raceglaze.co.uk/car-care-ext ... al-chrome/
What do you recommend? & method...
M
M
