Ignition Coil Diode Modification
Posted: 31 May 2007 21:24
I saw on the morini list an item about modifying the ignition coil by removing the copper plate riveted to the stator plate and replacing with 4 diodes 150v (1.5KE150CA). The diodes have to be fitted to a heatsink and wired in series between the green ignition wire and earth. I am about to fit the mod to my morini and wondered if anyone else had carried out this simple but apparently quite effective modification, and what results they had got.
Robin
Robin
