Swing arm washer/shim location
Posted: 19 Mar 2012 21:26
by morteach
Just removed swing arm pin from 1980 sport. All gone well but a washer/shim dropped out as I pulled the arm backwards. The internal diameter indicates that it could only have fitted on the left between the frame and the swing arm bush housing. The parts book shows it as 15.06.16 floating between the bushes so that's not a lot of use! Can anyone confirm its location as the manual doesn't give any info on this job?
