350 Carburettors
Posted: 27 Jun 2007 14:42
				Hi All,
My 350 Sport has done 92000 miles from new, and despite new slides, I have come to the conclusion that the carb bodies are worn out. I have some 350 Dart carbs (VHBZ25HS) and wonder if anyone has any experience of using them on a 350 Sport (originally VHBZ25BS).
On the face of it, both are notionally 25mm carbs, but with substantially different jetting. Externally only the vent pipe for the float chamber is different (pipe fitting instead of drilled hole) but internally the 'venturi' where the slide is, appears smaller, with a pronounced 'step' in the bore. Anyone know if the venturi is indeed smaller, hence the need for smaller main jets?
Is it a simple matter of replacing slides, jets etc with the appropriate parts for a Sport, or am I about to open up a whole new can of worms?
Thanks in anticipation,
