6 speed gears question
Tom
Post by Tom »
Who knows if this is a 3 1/2 or 500 Sei six speed cluster? Thx!
Looking at the shape of attachment of the primairy drive sprocket, i would say 3 1/2?
Tom
Re: 6 speed gears question
Hi, the 500 final drive spocket and shaft are splined, whilst the 350 spocket and shaft has two flats, so it looks like a 350 ?
hope this helps
500 has a bigger clutch input spline, needle roller thrust bearings and as said previously, a splined output.
Definitely 350.
Tom
Post by Tom »
Thank you guys, as i thought, 3 1/2. So the 'modulair' system Morini used isn't that straight forward afterall.
Tom wrote:Thank you guys, as i thought, 3 1/2. So the 'modulair' system Morini used isn't that straight forward afterall.
Why would you say that?
Any gearbox 'module' from 124 to 507cc, 5 or 6 speed will fit in the cases. SIMPLE!
Tom
Post by Tom »
Thanks for the reminder, i was about to sue Lambertini...
:mrgreen:
