				L5 cam valve clearances sanity check
				Posted: 10 Mar 2015 12:09
				by 72degrees
				Right, so I'm doing a long overdue 'full' service on the 2C/375 and have come to check the valve clearances. I recall the late Phil Smith advising me to run with 6 thou (0.15mm) after he put the L5 cam in for me many years ago. Is this still the conventional wisdom? The Dutch Morini club's web site suggests so, but when I took it out on Saturday it did seem particularly clattery. I've no doubt the rocker arms have grooves worn in them so last time I set them after having to do a front head change I erred if anything on the slightly tight side. To be honest, I'd much rather it be a bit rattly than burn valves, but thought I'd ask what others do - Evguru for example?
				Re: L5 cam valve clearances sanity check
				Posted: 10 Mar 2015 18:45
				by norbert
				I´m running my 501 with L5 cam and 0,1mm clearence for some 60000km without problems.
				Posted: 10 Mar 2015 18:57
				by 72degrees
				That's encouraging. The check revealed that they hadn't moved from the tight .15 verging on .13 that I set them to last time, but I may try nearer .10 and see if that helps the noise. Sewing machine quiet it's not. It hasn't been apart for 25 (or is it 30?) years, but hasn't covered anything like 60000 Kms. It may be that I've been spoilt by the new-fangled liquid cooled bikes I've been riding recently, but it does sound a bit like a bag of nails. No sign of anything on the oil screen and only a small amount of stuff on the magnetic drain plug, so fingers crossed.
				Posted: 10 Mar 2015 21:01
				by norbert
				Riding a 500 or 501 we have to be a bit careful:
If the clearence disapears in short time there might be a problem of setting seats because of the famous rift between them. Meanwhile this crack is not very great you can carry on quite a long time. But one day the material comes up an then one other day the seat will get removed >less clearence.
Another reason might be a worn thread of the studbolts of the "balancines".
But I don´t want to worry you! Just control if clearence is disappearing again
				Posted: 10 Mar 2015 22:56
				by EVguru
				I have a data sheet in Italian suplied to me by Hermy that indicates 0.15mm for the 2+2 and L5 cams.
				Posted: 11 Mar 2015 08:14
				by norbert
				Ok, maybe I should try with 0,15.
On the other hand, never change a winning team
				Posted: 11 Mar 2015 10:51
				by MarkB
				I always find that earplugs are a great help if you're worried about rattly tappets...
				Posted: 11 Mar 2015 22:57
				by norbert
				MarkB wrote:I always find that
what is that?
				Posted: 12 Mar 2015 22:15
				by SupermotoDave
				MarkB wrote:I always find that earplugs are a great help if you're worried about rattly tappets...
You are supposed to say "who said that"
				Posted: 13 Mar 2015 09:57
				by norbert
				Ah, now i got it, what earplugs are
Mark, I´m with you
