seal size
Posted: 25 May 2015 09:57
I've removed the lip seal that goes between the crankshaft and oil gallery in the engine casing but it's in such a state that I can't read the size, anyone know what I should be shopping for?
Also I've removed the cam shaft seal from the same casing. This shows 1326/5. I'm assuming this translates to 13mm id, 26mm od x 5mm so will this do the job: 13x26x5mm Nitrile Rubber Rotary Shaft Oil Seal R21 / SC ?
Thanks for your help!
Bob
Bob
