Pick Up wiring
SoloFrenos
Pick Up wiring
Post by SoloFrenos »
Hi everyone, simple question. I am trying to wire up my ignition with a new 'transducer' set from NLM, I have two red wires coming form the pick up, one with a little white sleeve on it. Can anyone tell me if the wire with the white sleeve indicates the front or rear cylinder? The NLM instructions says the wires are different colours, and i cannot find reference to it in any of the manuals i have!. Thanks, Tony
Re: Pick Up wiring
You're on the right track there, the little white sleeve would normally have had a number '1' on it and it does go to the front cylinder.
SoloFrenos
Re: Pick Up wiring
Hi Steve, Thanks for that, think my '1' must have worn off... i can now go and see if it ill start :o)
Cheers, Tony
