520 chain on a 350???
smotorboy
Post by smotorboy »
Hello all,
Are there 520 or 525 front sprockets for the 350 morini available anywhere???
Robert in California
Re: 520 chain on a 350???
I'd say NLM. I know you're over the water but they will be the most likely source of supply. The Kanguro and I think Camel were 520 so they should be easy to find, but I wonder if you're hoping to raise the gearing too? That might limit the availablability a bit. If postage is really prohibitive then grinding the original off and welding new blank sprocket on may be another way to go.
I nearly always convert to 520 when replacing the chain and sprocets and use the extra room to safely fit an O-ring chain.
I've bought front sprockets from Sprockets Unlimited (also know as 'The Chain Gang') in the past, but they were waiting for stock last time I asked.
NLM carry them in stock.
smotorboy
Post by smotorboy »
Great information,,, thank you both !
