				520 chain on a 350???
				Posted: 01 Aug 2015 03:18
				by smotorboy
				Hello all,
Are there 520 or 525 front sprockets for the 350 morini available anywhere???
Robert in California
				Re: 520 chain on a 350???
				Posted: 01 Aug 2015 20:22
				by Steve Brown
				I'd say NLM. I know you're over the water but they will be the most likely source of supply. The Kanguro and I think Camel were 520 so they should be easy to find, but I wonder if you're hoping to raise the gearing too? That might limit the availablability  a bit. If postage is really prohibitive then grinding the original off and welding  new blank sprocket on may be another way to go.
				Posted: 02 Aug 2015 07:58
				by EVguru
				I nearly always convert to 520 when replacing the chain and sprocets and use the extra room to safely fit an O-ring chain.
I've bought front sprockets from Sprockets Unlimited (also know as 'The Chain Gang') in the past, but they were waiting for stock last time I asked.
NLM carry them in stock.
				Posted: 02 Aug 2015 13:51
				by smotorboy
				Great information,,, thank you both !
