front wheel bearing and that pesky speedon drive
Tim
Post by Tim »
Hi folks
my first post on the site and a query that's been dealt with before but I couldn't find an answer to my particular issue.
I've changed wheel bearings a few times so know the routine but I cant see how the right hand bearing comes out. There seems to be an alloy centre to the speedo drive (not the cover that connects to the speedo cable) that sits in front of the bearing, but I cant tell if the bearing is supposed to push it out, or if there is some other way of removing it prior to drifting the bearing out of its recess. If it helps I'll post a photo
all help gratefully received
Tim
