Clutch question
Posted: 05 Apr 2017 08:40
				My 350K2 has been off the road since November, while the tank, etc were away being painted.  Now reassembled, I got ready for a celebratory ride, only to find that the clutch wouldn't release.  Last year I fitted new friction plates (NLM) and checked and cleaned the metal plates.  This was done following the instructions in Paul C's excellent video, so the metal plates were given the orbital sander treatment.  Since then, the bike has done about 1000 miles.  The clutch has always dragged a bit and it is impossible to engage neutral when stationary.  In addition, false neutrals have always been a bit of an annoyance.
I now stripped the clutch and found as expected that most of the plates were sticking together and had to be prised apart with a screwdriver. There was no contamination, in fact the plates all looked clean and dry - but sticky. I cleaned everything with brake cleaner and scuffed the surface of the friction plates with 180 grit emery. I also repeated the sander treatment on the steel plates, though they appeared clean anyway, with no burrs, etc.
That cured it and the clutch is significantly better. Much less tendency to drag, less evidence of false neutrals (the one between 5th and 6th is still an annoying problem) and you can even select neutral when stationary - well, sometimes!
Has anyone else seen this problem? I wonder if it will recur?
Joe.
Joe.
 That has new friction plates, plain plates, and springs. It also has the 'spring assistance washers' borrowed from the 375 so that probably is inclined to stick the plates up a bit if not used regularly. Only done about 100 miles if that. It doesn't drag at all but is inclined to be a bit switch like and grabby. The conical plate is in the Evguru advised position. I guess I will have to check the end float again and review the condition of the centre and basket. I dressed them with a fine file to remove notches and I've seen much worse without similar symptoms. Didn't notice any stickiness last time it was apart. When I find a tuit I'll try your scuffing trick.
