				Ignition wiring
				Posted: 05 Apr 2017 19:57
				by fastharry
				Can anyone give me a clue as to what wires should be joined together to get the ignition to work on a battery less race bike, on a 81 350 sport. i don't want an ignition switch, just enough to make it spark and get rid of everything else. regards, Harry.
				Re: Ignition wiring
				Posted: 05 Apr 2017 22:07
				by Steve Brown
				All you need to do is use the green wire from the flywheel/rotor to power the ignition transducers (as normal) and run another wire from that green to a kill switch that earths the green wire. It's the same as MX and trials types that run without batteries and charging systems. Just remove the reg/rec and battery and all the kit that uses DC power. I'll have any unused working electric kit in exchange for wiring the job for you!
				Re: Ignition wiring
				Posted: 05 Apr 2017 22:50
				by fastharry
				Thanks for the reply Steve, i did work it out about half hour ago.
