Mayonnaise
Posted: 16 Apr 2018 07:00
				I know this has been discussed some while ago however......
My K1 has a tendency to produce water vapour which then turns to mayonnaise,coming mainly via the rocker breathers, though I can see condensation droplets in the main crankcase breather.So I changed the oil and I can see a couple of drops of water.I have replaced the oil then thrashed the bike for at least 30 miles or so up to Okehampton and round to Tiverton and back. I then can still see suspicious evidence of water forming in the breathers.I removed the rear rocker cover and briefly ran the motor.Could not see anything untoward.Clearances are 10mm. I replaced the cover. Next I ran the engine with both breather tubes off. Putting my finger near the vent on the front rocker cover I can feel nothing or a very minimal draught. When I repeat over the rear vent I can feel appreciable draught.So I am guessing this indicates engine pressure getting through on the rear cylinder. The bike has always done this and is since 2016 sporting new pistons and rings and the bores were honed. It uses no oil nor can I see evidence of anything coming out of the silencers with the throttle closed coming down Telegraph Hill.
I will do the obvious and swap the rocker covers in the first instance. I assume this is water from combustion. I am avoiding sub 10 mile runs.
Any suggestions greatly appreciated, short of riding around Cordoba or Jaen in July.
