				While the front cyclinder gently weeps
				Posted: 16 May 2018 21:26
				by Lewes96
				Slight oil seepage from the bottom of the front cyclinder - any thoughts?
				Re: While the front cyclinder gently weeps
				Posted: 16 May 2018 22:34
				by 'It must be a .....'
				Hi, had the same problem occur on the front cylinder base on a 500 and fixed it by using Wellseal instead of the recommended silicone gasket compound.
I lived with the oil seepage for a while before fixing the problem; the rear was fine but I changed that too.
Not a serious problem, just enjoy!
PS Clean all jointing surfaces with a solvent first; Wellseal also makes it easier to separate  parts and clean the jointing surfaces.
And is far better than Blue Hylomar if used on the clutch bearing sleeve.
				Posted: 18 May 2018 19:01
				by 3potjohn
				I'm a believer in threebond sealant myself.Not a trace of doubt in my mind... Or you could just let it be. I've got a feeling,it won't be long that in spite of all the danger you'll get that leak sorted and you'll soon be happily riding down that long and winding road. Then you'll be glad all over...
OK I can't keep this up any longer.
				Posted: 18 May 2018 22:44
				by Lewes96
				What happened to Paul, Ringo and George?
				Posted: 19 May 2018 16:19
				by Lewes96
				On a more serious note, it means a taking the head and barrel off to clean up and put the sealant on?
				Posted: 19 May 2018 19:01
				by Steve Brown
				Yes. Seriously.
				Posted: 20 May 2018 20:02
				by Lewes96
				Definitely a job for the end of the season then!
