Fairing
Fairing
Help, I am looking for someone who has a 350 Sport K1 with fairing attached as I need some pictures of the mounting arrangements for the lower fairing panels. I need pictures of the inside and outside upper and lower mounting arrangements so that I can complete my build/restoration. Many thanks.
				Stubaker58
Re: Fairing
Hi Tim,
You just missed the boat, my recently acquired 1979 Sport had a handlebar fairing and “leggings” fitted but I took them off! I’ve got the fittings etc and could send a picture of those if you want. The lower fitting went onto the engine mounting bracket but did not use the engine bolts, the upper fitting was up under the tank somewhere!
Re: Fairing
A picture of the fittings would be great thank you.
It would give me an idea of how it goes on then I can make some fittings to match.
Many thanks.
Tim.
Many thanks.
Tim.
				Stubaker58
Re: Fairing
Hi Tim
Having trouble uploading the photos, PM me with an email address an£ I’ll send them to you
Stu
Stu
Re: Fairing
Hi Stu,
Will PM now.
Thank you.
						Will PM now.
Thank you.
