repairing regulators
buzby
Post by buzby »
I have a faulty regulator from a 75 Strada which I believe is called a single phase type -2 yellows and a brown connected to it.
My query is has anyone tried repairing these? With the cover off there seems to be 2 diodes pressed into the case which I have tested with a meter,both are faulty. There are no numbers visible and the Dutch Morini site has no useful info on this regulator, any help would be appreciated,
thanks , Dave.
They aren't diodes, they're Thyristors or SCRs (Silicon Controlled Rectifiers). They are like a diode, except you need a gate signal to turn them on.
The Dutch site does have a circuit diagram for that regulator;
http://www.motomoriniclub.nl/regelaar.pdf
They won't produce any output if there is too low a voltage on the control pin, the brown wire in this diagram;
http://www.morini-riders-club.com/thebi ... 05pole.gif
Check the voltage on this pin (with the ignition switch in all positions) before drawing any conclusions.
