Transmission noise.
Posted: 23 Nov 2019 11:40
I am quite a new owner of a Moto Morini 350 Kanguro X2, which is running perfectly ok, however with following exception:
On ‘throttle off’ (engine braking) there is a noticeable transmission noise (in any gear). I first believed this possibly come from the chain idler roller and made a new one with a proper sprocket (which seems to be a good modification), but this didn’t solve the mentioned noise in question.
Has anybody experienced the same ‘throttle off’ noise problem?
Could this be created by axial play in the helical gear primary transmission? (I have not yet opened up the engine transmission cover.) If so, which is the best method solving this?
