350 Strada Cush drive
Sicxtyone
Post by Sicxtyone »
Evening all,
Please can someone in the know inform me as to whether the Cush rubbers are the same on all models.
Mine is pretty worn out with about 3 to 4 mm of play. I have the part number for the 500, M430639 but I'm having problems accessing the 350 parts lists. No combination of password/login seems to work, oh and I have renewed!
Graham
Re: 350 Strada Cush drive
Pretty sure they are the same. Not got part numbers to hand to check but all the ones I've seen look identical, even with the Camels and Kanguros. Never known one to fail either, they seem indestructible!
Sicxtyone
Post by Sicxtyone »
Thanks Steve,
It's not fallen apart but maybe replacement could help the slight juddering pulling away. 43 years and 85,000 miles so not complaining.
M'dina have 2/3 options at different prices so wanted to make sure I order the right one! :roll:
My 350 parts list definitely has 430639 [EDIT!]
However, NLM and Mdina lists also have a 'cush rubber' 430829 - for ?
The 250 2C is definitely different - 430507 I've had to replace one of those - but to be fair on the 2C with 375 hill climb bike ;)
acemorini
Post by acemorini »
Hello Graham,
I probably have some Kangaro ones in the shed, and if Steve is right that they are the same then you can have them.
Regards Pete.
Sicxtyone
Post by Sicxtyone »
Hi Pete,
Thank you definitely interested in one from the shed! If you could put one by for me that would be great.Perhaps I will have a ride up to you during the week sometime when the weather allows.
Graham.
acemorini
Post by acemorini »
Hello Graham,
No problem.
Regards Pete.
